How to separate tray 3 unit on lj4050
  • axyun
    • Aug 2007
    • 1323
    While I was working on lj4050 I caused the pickup spring and pickup spring clip to come loose on tray 2. At the risk of sounding foolish I it is difficult to put these back while tray 2 + tray 3 remain together and appears a lot easier to do if separated. I am not sure how to do that. Do I have to turn over machine + remove modular plate for tray 3 then gear train assm then module side rails + then tray 2 modular plate. I was hoping the machine would just lift off of tray 3 unit but wasn't happening. Thanks for humoring me. Frank/ActionPhotocopy
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    I am not sure what is holding your together, but they do stack. I do not recall them being screwed together.
    • axyun
      • Aug 2007
      • 1323
      That's what I thought but i was unable to pull apart between tray 2 base and tray 3. I thought that i remembered tray 3 as an option and that the machine just fit right over tray 3 unit and could be easily lifted. Maybe the 4000 was like that and maybe the 4050 came standard with 2 casettes hwich were locked together somehow.Frank
      • Brian8506
        • 1667
        If its a TN model they're screwed together. A little time consuming. Kinda difficult to put in a post without being in front of a machine and not having to do it that often.
        • axyun
          • Aug 2007
          • 1323
          Hi Brian. It IS a 4050tn. Could you tell me where the screws are? I have 4050 manual but in the disasssmbly/removal section all i saw was taking apart unit as I described above taking off modular plates and gear unit etc. Is that what you are referring to or is it easier? Frank
          • prntrfxr
            • 1622
            You have to split the machine in half. Start by removing the 2 very long tray 1 p/u asm screws, remove screw on the left side under the fan, remove the formatter, disconnect the purple cable from the lower portion (under where formatter was) and lift printer straight up. Then the lower unit can be accessed from the top. If you remove the screws that connect only tray 2 to tray 3 you shouldn't have to remove the metal plate and rails of tray 2 to reach tray 3. Hope this helps you.
            Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
            • axyun
              • Aug 2007
              • 1323
              Thanks prntrfxr. I was just looking for my crowbars when you posted just in time. Frank
              • Brian8506
                • 1667
                I'm glad he explained that one and not me. I would've needed the machine in front of me. It helps when you do it regularly. Good explanation prntrfxr!
                • axyun
                  • Aug 2007
                  • 1323
                  Actually the instruction would separate upper part of machine from 2 trays which still leaves trays together. I wanted to split trays 2 + 3 so I could have room to reinstall pickup clip and spring.
                  I was able to manage it without separating trays so all is well. Thank to all for your help. Frank
                  • ESG
                    • Dec 2008
                    • 17
                    find in the manuel how to remove tray 2 and tray 3 paper feed unit, it explains how to get to both of the trays becarfull when taking tray three aprt for the plastic latch and spring i the front / right of tray 3. It is a B****H to put back on.
                    • slybot
                      • Sep 2010
                      • 165
                      ouch! she is going to have you for that
                      • axyun
                        • Aug 2007
                        • 1323
                        Thanks ESG. Call was done and all okay. Frank
                        • prntrfxr
                          • 1622
                          It's ok, I'm used to it. I just kind of ignore it and go on.
                          • axyun
                            • Aug 2007
                            • 1323
                            Thanks again Lori. Your instructions were very step by step informative but somehow when i got down to removing formatter and disconnecting cable I was still having a problem. I can't exactly remember as it has been 3 months. So instead of trying to go further with disassembly I made a serious effort to install clip and spring without further disassembly and managed to do that.
                            I probably missed something in your instruction. I have been in the business since 1968 but spent the greatest part of those years in office and started servicing machines myself on a regular basis in mid 2007. I had picked up things along the way and dabbled in service from time to time over the years when necessary. Without places like Copytech.net and talented and helpful techs like yourself I would have had to do something else. Frank
