Hp designjet 430c
  • thuo
    • 155
    Hp designjet 430c
    Hi
    i have a designjet 430c with a faulty power supply .it outputs only 5volts and no +24v, 12v,-12.I have checked the components appears to be o.k.
    anybody who has come across this problem. please asssit
    thanks
  • gerryhuerta
    AccService
    • Jul 2009
    • 198
    umm, im not exactly sure what your asking. What do you need help with? Does the powersupply work or not? Do you need help with the reassembly procedure with the power supply?
    • allan1
      +24 is for the drive motor..check for short or damages drive motors....try to replace the whole power supply unit...^_^...
      • thuo
        • 155
        Checked voltage output with the board out of the machine .only +5v is outputted.
        you can assist me with circuit diagram if you can
        thanks
