4650DN color registration
  • Cirrus
    • May 2008
    • 43
    Magenta on this printer out of registration. I am not finding any manual registration. I cleaned the color registration sensors and ran full calibration. Could anyone please give me an idea. The customer is a distance from me and I already spent too much time to give them no real answer.
    thanks
  • Rob Sandberg
    • Jul 2008
    • 275
    Here is the calibration procedure.
    Calibrate Now (HP Color LaserJet 4600 models)
    Use the following procedure to calibrate the printer whenever you replace the DC controller,
    the ETB, the drum drive motors, the drum drive gears, or a laser/scanner.
    1. Press to open the
    MENUS.
    ENWW Engine resets
    399
    2.
    Press to highlight
    CONFIGURE DEVICE.
    3. Press to select
    CONFIGURE DEVICE.
    4.
    Press to highlight
    PRINT QUALITY.
    5. Press to select
    PRINT QUALITY.
    6.
    Press to highlight
    CALIBRATE NOW.
    7. Press to select
    CALIBRATE NOW. Wait for the printer to calibrate.
    Rob S
    • CKHP
      • Dec 2010
      • 10
      Update the firmware and run 3 calibrations back-to-back. If still no luck, I'd start with replacing supplies (magenta cart, then ETB), followed by DCC. Normally F/W and Full Calibrations take care of this.
      • prntrfxr
        • 1622
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
        • faxman28
          • 435
          reset_nvram_dcc.pdfcolor_plane_reset.pdf
          try to reset the cpr on the dc controller, see attached.
