CM2320MFP with 9mm lines from each drum unit on page
+ More Options
Posts
  • jondanny
    • Aug 2010
    • 19
    I have in the field a HP Color LaserJet CM2320MFP and on every print or copy it comes out with a black, cyan, magenta and yellow line on the page. They are 9mm wide and evenly spaced the distance of each drum unit and edge to edge. Sometimes it will be 4 black lines and other times it will be overlaid with all colors. Sometimes it works great. I talked with tech support and they had me change the HV board. It didn't stop the problem but made it better for awhile. Now it's doing it almost all the time. I hope I'm making sense.
  • prntrfxr
    • 1622
    any way you can attach samples?
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • jondanny
      • Aug 2010
      • 19
      I'll see if I can. Might need help on that too.
      • jondanny
        • Aug 2010
        • 19
        I could scan them to an e-mail address if you like.
        • prntrfxr
          • 1622
          If you can scan them to your computer and save them as a file. All you would need to do is attach it to this thread. Paperclip icon above the message box when you type a message.
          • jondanny
            • Aug 2010
            • 19
            Just got home from copierville. I'll do that tomorrow when I get some time. Thanks for the help.
            • jondanny
              • Aug 2010
              • 19
              • jondanny
                • Aug 2010
                • 19
                [ATTACH]7857[/ATTACH][att[ATTACH=CONFIG]7859[/ATTACH][ATTACH=CONFIG]7860[/ATTACH][ATTACH=CONFIG]7861[/ATTACH]ach]7858[/attach]
                • jondanny
                  • Aug 2010
                  • 19
                  Sorry I repeated all the images. So what do you think?
                  • jondanny
                    • Aug 2010
                    • 19
                    Anybody got any ideas?
                    • prntrfxr
                      • 1622
                      1st. Make sure the printer is plugged directly into the outlet not a surge protector. Try a different outlet. To me, this looks like a Firmware/Formatter issue. Make sure you update the firmware. Then I would try a formatter if the other doesn't fix your problem.
                      • jondanny
                        • Aug 2010
                        • 19
                        It is plugged directly in the outlet. It's in a production environment, and they do have power issues at times. It's a DVD production and packing facility with lots of automated equipment. In fact, one of the production engineers was telling me how some of his equipment was doing crazy things. It's a very small office and I'll see if there is another outlet in there. Is there a way to flash the firmware or is that something I need to order. I know with our copiers I can go to our site and download our firmware. I don't have a service manual for this machine so if you have part numbers for both I would appreciate it. Thanks again and I'll keep you informed on what I find out.
                        • prntrfxr
                          • 1622
                          The newer HP printers are very power sensitive, so this could definitely have something to do with it.
                          Yes, you can go to and download the firmware upgrade. Make sure you get the right one, and read the read me file and follow it exactly or you'll have problems. I think firmware is embedded on that machine, but I could be wrong. CC399-67901 is the part number for the formatter.
                          • jondanny
                            • Aug 2010
                            • 19
                            Thanks again and I'll post what I find.
                            • ucinn
                              • Jun 2009
                              • 383
                              I had an HP color, differe3nt model doing something similar. They told me to replace the HV also to no avail. It ended up being the txfer belt assy. Don't know why, but that took care of it.
