i have a HP LJ 9000 with a 3k finisher. when directing paper to the finisher, it still turns and goes to the inside. after two sheets, it shows a jam. i know this is because its not going to the finisher. do i need to replace the entire diverter section or could something else be causing the paper not to turn. i see there are a couple of plungers on the diverter that are activated (or supposed to be) in the process. anyway to test these? i'm a copier tech by trade and dont know a whole lot about HP, but being forced to learn without resources.
thanks!
if you have the part number for the diverter that would be great as well.
thanks!
