HP Laserjet 4050 "Unable to collate"
  • J_Lee
    • Oct 2008
    • 111
    Anyone ever seen this error? It all started when they installed new computers (vista). Prints this page out when you try to print more than one 'copy' of a ANY document.Document.pdf
  • prntrfxr
    • 1622
    Sounds like a driver conflict to me. Update drivers and firmware.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • J_Lee
      • Oct 2008
      • 111
      Ok, I swapped out the formatter and I didn't see a newer firmware version 19990309 MB6.28.. The customer had the machine hooked up via parallel port. I hooked it up with a 620 network card and it's still doing the same thing!! Any other suggestions please
      • J_Lee
        • Oct 2008
        • 111
        Also tried a cold reset before the new formatter board
        • prntrfxr
          • 1622
          Can you print from the control panel without a problem?
          Did you delete out the old drivers and install new ones? Collate is selected via the driver. It could even be a menu setting set wrong.
          Update the firmware too.
          for the drivers and the firmware
          • J_Lee
            • Oct 2008
            • 111
            I was speaking to someone at tech support with one of our distributors and they said its a vista/driver conflict with this older machine.. I'm trying different drivers now, I have never seen this before. Thanks for your help, will post results.
            • J_Lee
              • Oct 2008
              • 111
              And yes I can print. The problem is: printing more than one is when error occurs
              • J_Lee
                • Oct 2008
                • 111
                PCL 6 Universal driver fixed the problem. Thanks again
