I had this problem with another printer is this a driver issues , from any computer when printing it just starts printing hearts all kinds of weird fonts only in black and i cant get a normal print out of it. How can this be fixed on this printer and what can cause this? any help appreciated is tere a way to reset as well
CM2320 Prints lines of unknown fonts
Sounds like a driver issue to me. If all the computers are doing it, I'd suspect the driver is installed on the server. Try installing it locally on one PC and see if that fixes it. You can go back and install it on the server after you see if that's going to solve your problem. -
I agree.Definitely wrong driver.If it ain't broke, don't fix it
A picture is worth a thousand wordsComment
I installed new drivers locally on all pc's reset the nvram and restarted the print spoolers service on the server with Hp support. The problem went away and then the next morning it started doing it again, what else can i try as soon as i plug the network cable back to the a hub it would start doing it again what else can this be??Comment
I installed new drivers locally on all pc's reset the nvram and restarted the print spoolers service on the server with Hp support. The problem went away and then the next morning it started doing it again, what else can i try as soon as i plug the network cable back to the a hub it would start doing it again what else can this be??If it ain't broke, don't fix it
