hp2840 uneven density on copies and prints
  • tpolley
    • 12
    i have a customer with an hp2840 with uneven density on copies and prints. all colors. the developer units are within their yield. he had a remanufactured image unit (drum and ITB) wich was only at 20%. the image was uneven on the image transfer belt. i couldn't get to the drum but i assume it was uneven on the drum also. i told him to buy an OEM image unit from hp because i've seen alot of aftermarket image units fail prematurely. well, he called me this afternoon and said he bought a new oem image unit and its still uneven. now i'm suspecting the laser unit(s) or the carousel unit may be out of alignment. what do y'all think?
  • Caldo
    • 69
    Sometimes remanufactured products do not work friendly with these machines, try have geniune image unit and color toners replace the remanufactured ones. Again if this does not help, i suggest you clean the image transfer belt and check the sitting postion of the belt for any slight movement.
    • JustManuals
      • Jan 2006
      • 9838
      Just Manuals | The Internet's largest collection of manuals | Instant Downloads - Just Manuals | The Internet's largest collection of manuals | Instant Downloads
      Paul@justmanuals.com
      • prntrfxr
        • 1622
        Carousels get out of alignment on these machines, the carousel bushings go bad, and even the carousel assembly.
        See attached Service Note...
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
