hp 2300n not feeding
  • knightfall
    • Jul 2006
    • 633
    I am having a problem with the hp2300n not feeding in fact the feed roller and the gears behind the board on the right side is not turning. Iam not too familiar wih the hp printers and any advice is greatly appreciated.
    Thank you.
    Get your facts first, and then you can distort them as much as you please.
  • prntrfxr
    • 1622
    Is the motor turning at all? The motor drives the main gear drive. The p/u solenoid permits the pick-up roller gear to turn with the gear drive at certain times.
    Troubleshooting Conditions
    If the connection linkage to the gear is broken or out of position, roller won't turn. Might be accompanied by noise.
    If the p/u gear is broken, roller won't turn. Might be accompanied by noise.
    It the solenoid sticks, roller sometimes turns.
    If the solenoid fails to move, main drive gears turn but p/u gear does not.
    If the main motor fails, no gear movement at all.
    If the main drive asm fails, noise would likely be present. Either grinding or seized up sound.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
