LaserJet M4345 MFP
  • aaupwsu
    [Misc] LaserJet M4345 MFP
    When I use the copy feature to make one copy of several different pages, the first page comes out fine but the remaining pages the image is lighter. I know it is not the ink cartridge.
    Also does anyone have a link to a good place to explain the scanning feature. We have tried and tried and it won't work.
    Thanks!!!
  • The Fixer
    • Dec 2005
    • 22
    Do a firmware upgrade, even if same version. Could have become corrupt. Also do several NVRAM Inits after.Toner could just be a bad one.
    • Papu
      Re: LaserJet M4345 MFP
      Clean transfer roller and its connecter (red wire).
      • prntrfxr
        • 1622
        I know this is probably something you've already checked but:
        Make sure economode is off.
        Are all of the originals the same that you're making copies of or are some of them copies? Copies of copies are going to be lighter.
        Do a scanner calibration and make sure the glass, white backboard, white mylar, and mylar strip is clean before you do it.
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
