4515x 13:06, 13:20 jam codes
  • mo0651
    • 1054
    Hello all, Got a 4515x with 128k prints on it. JAMS WITH THESE CODES BUT ONLY WHEN DUPLEXING. printed hundreds of test pages single sided. found a torn paper 2days ago and never jammed so I left. Anyone have any luck with these things?
  • The Fixer
    • Dec 2005
    • 22
    Chances are the registration is worn, and the feed assy. too. Sensors in the paper path may be dirty.
    • jsw2k
      • Oct 2008
      • 95
      Idon't have the manual for this model...what, specifically, are the definitions on those codes? Also, have you performed whatever PM steps are necessary at this point? (You probably should).
      • prntrfxr
        • 1627
        13.20 error is a generic paper jam and can occur anywhere in the printer.
        Where in the printer is it jamming? Where does the leading edge stop?
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
        • Wild Bill
          • Jul 2005
          • 774
          I suggest replacing the fuser assembly
          Izzy
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
