Hp color laserjet 2600n
  • shep
    • Sep 2010
    • 108
    We just got a 2600n printer in our shop to fix, it had a cyan toner blow up in the machine. cleaned it all out and now the prints are clean but the registration is way off, side to side and top to bottom. there is no reg. adj. that i have seen in the manual or on the control panel. I do not work on a lot of hp color machines. thanks for any help you all can give me thanks Mitch
  • prntrfxr
    • 1622
    Transfer belt has the color registration sensor, powered by the HVPS and controlled by the DC controller. Any one of those 3 could be bad. Printer is probably not worth it. Transfer belt is not as easy as other color HP machines to change (requires cover removal, several cables disconnected, and removal of hinges.)
    • shep
      • Sep 2010
      • 108
      Thanks ill look into those, sucks you cant just adjust it like most machines i work on.
