HP Laserjet 5550 error 50.4k help!
  • ngoclongchau
    • Apr 2011
    • 11
    Hi all
    I have an error 50.4k on a HP LJ5550 but not know how to fix, please help me
    Many thanks.
  • JustManuals
    • Jan 2006
    • 9838
    Just Manuals | The Internet's largest selection of manuals | Instant Downloads
    Paul@justmanuals.com
    • kuby
      • Oct 2007
      • 1403
      This is a fuser error.....replace the fuser.
      50.X FUSER ERROR
      For help press
      None A fuser error has occurred.
      X Description
      1 low fuser temperature
      2 fuser warmup service
      3 high fuser temperature
      4 faulty fuser
      5 inconsistent fuser
      6 open fuser
      7 fuser pressure release
      mechanism failure
      8 low fuser temperature
      (sub=thermistor)
      9 high fuser temperature
      (sub=thermistor)
      1. Turn the printer off and allow it to cool down.
      2. Reinstall the fuser, and check the connector (J100) that
      connects the fuser and the printer. Replace the
      connector if it is damaged.
      3. Turn the printer off and remove the fuser. Measure
      the resistance between the connector pins on the fuser. If
      resistance does not meet the following guidelines, replace
      the fuser.
      J100LB-5 to J100LB-6: 300 - 500 KOhms
      J100LB-1 to J100LB-2: less than 1 KOhm
      4. Check for continuity between connector pins J100-5 and
      J100-6. If there is no continuity, replace the fuser.
      5. Replace the fuser power supply PCB.
      6. Replace the DC controller PCB. Calibrate the printer
      after replacing the DC controller.
      • ngoclongchau
        • Apr 2011
        • 11
        I got it. Thank you very much.
