Laserjet 4600 top socket will not print cleanly
  • Thal
    • Aug 2025
    With the cartridge check disabled, I tested the black toner in another slot and it prints fine... but the top one still fails no matter what toner cartridge is in it.
    IF I apply a lot pressure to the door- forcing it in as far as possible- while doing a test print I can get a little black to print in normal mode- the it's extremely poor quality- barely legible but enough to get a configuration page...where the last recorded error was 54.18. I have replaced the color registration sensor SP12 and the DC controller assuming that this was the problem. Still no improvement.
    Note- the printer will give me a config page without pressure on the door... but absolutely no black toner at all. So all I get is a colored border no information.
    Looking for help or direction on where to go next.
  • prntrfxr
    • 1622
    See attachments. Particularly the one in progress (even though its says for streaking, missing black or light black also applies).
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • The Fixer
      • Dec 2005
      • 22
      The H/V charges the toners. Check the slots contacts, could be bent in too far.
      Replace the H/V
