Hp Color Laserjet 2840
  • Naveed Shahid
    • May 2008
    • 162
    Hello Every One
    I am facing a Problem Scanner Error 5
    any one have a good idea plz
    thanks
  • Brett207
    • May 2011
    • 35
    Hello,
    This is a problem with the Document scanner / flatbed scanner
    Try this;
    Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the
    power and wait for the product to initialize. Observe the document scanner movement under the glass, the lamp should illuminate, and then the scanner should move slowly as it seeks its 'home' position.
    If it doesn't move or appears to stall, (might make some noise) it might be jammed on the rail. this can be cleaned. Along with the underside of the glass.
    If the error persists, verify that all formatter connectors are firmly connected.
    If the error persists, update the firmware.
    If the error persists, replace the Scanner sub assembly
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from http://www.justmanuals.com
      Paul@justmanuals.com
      • mabawser
        Tech
        • Sep 2009
        • 121
        Just to confirm what brett207 has said.....
        and to add that the formatter could also be faulty and this is what has brought down the scanner.
        Depending on what you found with the scanner start up you are looking at a scanner assy at least and then possibly a formatter as well.
        • ucinn
          • Jun 2009
          • 383
          I found this elsewhere.
          I think I figured it out, at least for me and maybe a lot of you others who don't want to buy a new scanner just because the homing stripe got too dirty. On the bottom of the scanning glass at right end is the white stripe (and a black stripe next to it. I'm pretty sure that this edge is the home position, and it there isn't enough contrast for some reason for it to find home. I cleaned the glass with a Kim wipe, any lint free or lens tissue will do. After fighting with it for months, it's now working fine. If clean glass doesn't do it for you, take a Sharpie marker (or other indelible marker) and draw over the black area to reduce the glare from the glass where it should be black. Don't get any marker over the WHITE area. Report back here if that doesn't fix it!
          I myself had this on another machine not this model and cleaning the mirror right below the lamp worked... give those a try first... cheaper than the others
          • Brett207
            • May 2011
            • 35
            Excellent! all these ideas are good to try,
            Good luck!
