HP Laserjet 3015 Jamming
  • Smiley27
    • Apr 2011
    • 160
    [Jamming] HP Laserjet 3015 Jamming
    Alright,so Iv posted the video so you can judge what the hell is wrong with this machine.
    I'v checkd fusing unit,nothing seems to be wrong with it,mby some sensor?
    Judge by ur self..maybe I missd something
    Reply as fast as possible !
  • Eric1968
    • 2459
    Re: HP Laserjet 3015 Jamming
    You did not use the magic word.
    • Smiley27
      • Apr 2011
      • 160
      Great
      • JustManuals
        • Jan 2006
        • 9919
        YouTube - ‪Video0237.mp4‬‏
        Yes, hurry up he is waiting for his answer. Yes, you did miss something. MANNERS!
        • Smiley27
          • Apr 2011
          • 160
          God damit,no manners , no answers?
          • JustManuals
            • Jan 2006
            • 9919
            Correctamundo!
            • Brett207
              • May 2011
              • 35
              I suggest you try replacing the Fuser assembly. Older machine can have the lubricating grease in the fixing film dry out, which can cause the film to lag from the pressure roller driving it = paper jam!
              Can be intermittent.
              Check a printed image for a smudge effect in the halftone areas for an indication of fixing film lag.
              Good luck!
              • prntrfxr
                • 1637
                It seems to be a sensor/timing issue. The paper is not clearing the fuser exit sensor in the correct time. Something is retarding it. 1. Clean the sensor, 2. check the flag, 3. check the rollers and blow out any debris in the paper path (with fuser removed). 4. Replace the fuser. 5. Replace the sensor. 6. Replace the DC controller. Check all mechanicals first before moving to the electronic parts.
                Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
                • HenryT2
                  • 962
                  God damit,
                  WELL ........... that certainly isn't the magic word !!!!
                  "The Serenity Prayer" . . .
                  God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
                  • Rob Sandberg
                    • Jul 2008
                    • 275
                    It was with my mom, but it was not a good magic word.
                    OUCH
                    Rob S
                    • Smiley27
                      • Apr 2011
                      • 160
                      sensor is fine ... mby dried out under fixing film,if its not that ,then i quit ..
                      • hekotez
                        • Jan 2007
                        • 91
                        Honestly... i wouldnt want to be a client with you as a service tech :/
                        • Smiley27
                          • Apr 2011
                          • 160
                          fuser unit looks just fine,sensors / flags are okej,iv put lube under fixing film..same issue again ...
                          • roberts
                            Hi, first time poster here.
                            I have this exact same problem....exactly. Smiley27, did you ever find a solution? Anyone else?
