HP- LJ-2840 will not boot up.
  • BillAgudelo
    • Feb 2010
    • 84
    This customer complains about her LJ-2840 not getting ready. When I turn it on, It sounds like it is going to get ready, you can hear the carroussel turning, you can see the bar indicator on the display moving left very fast.
    But... that's it. It never gets ready, the indicator never stops moving left, no errors or messages, no more mechanical movement. By the way, the scanner never moves or lights up.
    Any Ideas ?... Please.
    Bill.
  • prntrfxr
    • 1622
    Re: HP- LJ-2840 will not boot up.
    I would probably never say this about any other machines than the 1500/2500/2550/2840 series printers, but...
    Do yourself and your customer a favor, throw it in the nearest dumpster and get a non-carousel machine. I automatically charge 2 hours labor for those things sight unseen. Reason: Everything I've ever done other that aligning the carousel, blowing it out, or replacing the maintenance kit has ended up taking that long. Then I give the client the quote for the repair and they tell me their going to get a new one.
    Check if the fuser's getting hot. If not, throw it out.
    Try to print an engine test. If it doesn't print, throw it out.
    • Lasersupplies
      • Jul 2011
      • 221
      It's an old printer with no redeeming features accept maybe the cartridges were easy to fill. It'll push you over the edge.Tell him to go on ebay and pick up a cheap cp1515 printer slow but good.
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
        Paul@justmanuals.com
        • Rob Sandberg
          • 275
          It won't even make a good door stop.
          Rob S
