ColorLaserJet 4600 52.1K error code
  • racer42
    • 18
    [Error Code] ColorLaserJet 4600 52.1K error code
    51.2K printer error. reseated connectors. K is not in the manual I have. Has 0-3 options. What the heck doed the "K" signify?
    Thanks all...
    There I was, 20.000ft. surrounded by commies, no fuel, shot to hell, cockpit panel fire, in an inverted tailspin, and I had to pee...
  • prntrfxr
    • 1622
    Re: ColorLaserJet 4600 52.1K error code
    51.XY errors are laser scanner errors
    x=
    1 is beam detect
    2 is laser error
    y=
    0 is no color
    K is black
    C is cyan
    M is magenta
    Y is yellow
    SM resolutions:
    1. cycle power
    2. reseat dc controller connections J1009-J1012
    3. replace affected color laser scanner (perform 3 full calibrations afterward)
    4. replace dc controller
    Did you pee on the cockpit panel fire to put it out?
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • racer42
      • 18
      x=
      1 is beam detect
      2 is laser error
      y=
      0 is no color
      K is black
      C is cyan
      M is magenta
      Y is yellow
      SM resolutions:
      1. cycle power
      Yeah, did think to pull all the circuit breakers first, all I had was a silkworm and a box of ripcord handles...
      Thanks very much! my manual has nothing but numbers for the Y variable. Must have changed the SW version.
