Hp coloe laserjet 1015 mfp toner cartridge
  • Jonzeboy
    • Aug 2025
    I have a question about hp's toner...
    I have a friend and she used to print b/w and now is the printer telling that the toner is empty and the printer stops printing.
    I found that there are a funktion called overide toner on some models but not on this one.
    Can I make factory default or a nv-ram reset so the machine resets the counters or is the counters really in the chips?
    What happens if I remove the chips? Can I print then or wont the printer allow it?
    Thankful for answers
  • Lasersupplies
    • Jul 2011
    • 221
    Re: Hp coloe laserjet 1015 mfp toner cartridge
    When the chip is removed from the toner i am sure that it wont be recognised in the printer. Most of hp devices come with an override. Have you tried the following?
    Cartridge-out override can only be enabled from the control-panel menu.
    1. From the main menu, press the navigation arrows to choose System setup and press OK .
    2. Press the navigation arrows to choose Print quality and press OK .
    3. Press the navigation arrows to choose Replace supplies and press OK .
    4. Press the navigation arrows to choose Override out and press OK .
    5. Press OK .
    The factory default setting is Stop at out .
    • Jonzeboy
      I cant find it in the user manual...
      5. Press OK .
      • Wild Bill
        • Jul 2005
        • 774
        He just gave it to you
        Izzy
