HP 4730 MFP print error
  • atiq
    • Jun 2010
    • 25
    One of our clients has a HP 4730 MFP at the moment and the problem they are getting is, when the document has printed it showing a double print and blur on the paper. I have changed the toner and asked them to re-install the print driver.
    Any suggestions would be helpful.
    Atiq
    There are three types of people in this world: those who make things happen, those who watch things happen and those who wonder what happened.
  • prntrfxr
    • 1622
    Re: HP 4730 MFP print error
    Go to the Diagnostics menu and print the PQ Troubleshooting pages. This will isolate each color. Additionally, use the corner L's to see which color is drifting out of position. Since you already changed the cartridges we'll go to the next step. This is from the manual.
    1.) Perform a calibration. This will be located in the Print Quality menu.
    2.) The ETB is not rotating properly. Replace the ETB (transfer belt)
    3.) ETB motor gear is damaged. Replace ETB motor.
    4.) Drum motor drive gear is damaged. Replace the drum motor drive for the affected color.
    5.) The color-registration detection unit is defective. Replace the color registration detection unit.
    6.) Laser scanner is defective. Replace the laser/scanner for the affected color. Calibrate the MFP after replacing the laser/scanner.
    7.) DC Controller is defective. Replace DC controller. Calibrate the MFP after replacing the DC controller.
    Make sure BEFORE you order any parts for this machine you use the Product Code on the printer bar code label. Some different models of these printers use different parts. In addition, there is a 4730 mfp and a CM4730 mfp. Some parts are the same, but some are different.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • ucinn
      • Jun 2009
      • 383
      Atiq
      Probably the fuser worn.
      • prntrfxr
        • 1622
        That could be also. The first thing to do would be to do a print/stop test or a half page test to look at the page before it goes into the fuser. If it's nice and clear the problem is the fuser. If not, see my prior post
        -- Sent from my Palm Pre using Forums
        • atiq
          • Jun 2010
          • 25
          Thanks for that, the printer needed calibrating. as we don't work with HP we were a bit stumped. - Thanks
          Atiq
