hP 9050MFP FIRMWARE
  • Brianmhl
    • Aug 2025
    [Misc] hP 9050MFP FIRMWARE
    Hi i have an Hp 9050mfp which i have installed a new CF card which looks like it has no firmware on it ( the cf card in the manual is no longer availble ) is there any other way of uploading the firmware to this as i only now from web browser or jetadmin ?
  • prntrfxr
    • 1622
    Re: hP 9050MFP FIRMWARE
    You should be able to update firmware through Jetadmin. Follow the installation instructions on HP's website.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • prntrfxr
      • 1622
      If you had a service manual, you would also have the instructions to do this. I will give you just this part. If you want to continue to work on these machines, you may want to get a service manual. Ask manuals4you. He sells them.
