I have an HP9500 MFP with "Check scanner lock message" the reason for this is that the scanner motor does not move or light up when booting.
I do not get the usual 30. error codes and yes the scanner lock is off. I have noticed that the document feeder does not fire up either, further to this the scanner fan doesn't turn but still no errors! I have replaced the scanner power supply but there still doesn't seem to be any 24v coming from the copy controll board? The rest of the machine boots up ok and i can print out reports etc. The power led on the connector board is lit but not the scanb led. Has anyone changed the copy controller board or is this rare? Any suggestions would be appreciated.
