HP 4600
  • Lasersupplies
    • Jul 2011
    • 221
    HP 4600
    I Have a 4600 thats just started printing blank pages and i am not sure what is the cause! has anyone come across this before?
  • mo0651
    • 1054
    Re: HP 4600
    oem toners? when you print black only? Little more info!
    • Lasersupplies
      • Jul 2011
      • 221
      Re: HP 4600
      nothing prints at all, i have changed all oem toners and the machine is still printing blank. Changed the dc controller board and formatter board and still blank. Does anyone know what the cause could be? Thanks
      by nothing prints i mean, i get blank pages. thanks
      • mo0651
        • 1054
        Re: HP 4600
        could be the laser shutter drive not working. No error codes?
        • Lasersupplies
          • Jul 2011
          • 221
          Re: HP 4600
          Im not recieving any error codes, could it be the scanner? all shutters are oping and closing
          • prntrfxr
            • 1626
            Re: HP 4600
            Open front door, transfer door and bypass the front interlock switch.
            Remove the cartridges
            Go to the Diagnostics menu > Component Test > Alienation Motor Test.
            Watch black plates (4) in the back. They should go up, down, and in the middle. If they don't, the plates could be broken or out of position. If these plates look fine, remove left cover (put top cover back on) and perform the test again. Watch to see if the alienation (developer disengagement) motor turns, long black linear gear goes up and down, spring at the bottom is not missing, and white gear at the top is damaged.
            All of these parts control cartridge open and closing. Send me a PM with your email address and I'll send you my 4600 troubleshooting guide, if you would like to know more.
            Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
