Help with HP Designjet 5500 Streaking Problem
  • JStander573
    Hi,
    I am using an HP Designjet 5500 at work and on some of my prints I am seeing a series of vertical streaks that generally begin towards the end of the print, towards the end of printing.
    It was calibrated a day ago, everything seems to be in good working condition, does anyone have any suggestions as to what may be the issue and how to go about solving the problem?
    Thanks for the consideration and any help.
    - J
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    Re: Help with HP Designjet 5500 Streaking Problem
    The streaking can be from a bad printhead. Visually check for air in the tubes. If you see air, it needs to be bled out. Then you must narrow it down as to which head needs to be changed.
    • good
      • Sep 2012
      • 51
      Bad printhead. Replace your printhead with oem.
      • JustManuals
        • Jan 2006
        • 9838
        That SAME answer was given last year.
