Magenta not printing properly
  • LennoxD
    • Sep 2011
    • 82
    Magenta not printing properly. Cannot make the color red properly. Please find attach sample. Any suggestionsHP2600 Sample.pdf
  • Sofronii
    • 8
    Re: Magenta not printing properly
    Magenta laser stands at the lowest position from 4 colors.... so all the dust and toner is in the laser scanner assy.
    You need to clean the optics.
    • prntrfxr
      • 1637
      In order to clean them properly, you will need to physically remove the laser scanner from the printer, hold it up to the light, and wipe the lenses down with a lint free swab.
      Remove the rear cover, the formatter, the DC controller, move the wire harnesses without completely removing them to reach the screws underneath and on either side of the printer that hold the metal plate upon which the formatter and DC Controller are seated, (be careful when disconnecting the FFC's), and remove 2 screws in front of you and 2 underneath the machine (sometimes covered by leaf springs) that secure the laser scanner. Reverse the process to reinstall.
      Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
      • LennoxD
        • Sep 2011
        • 82
        Thanks very much will do that.
        • good
          • Sep 2012
          • 51
          Sometimes the problem is the cartridge.
          If you use generic cartridge and not oem.
          • atech
            • Aug 2010
            • 89
            Originally posted by LennoxD
            Magenta not printing properly. Cannot make the color red properly. Please find attach sample. Any suggestions[ATTACH]13153[/ATTACH]
            exactly it is a laser problem you need to clean the lens and the polygon motor. after doing this try to print the supply status, you will see the percentage of the toners indicated by its respective color.sometimes the text print has a shadow of magenta or other color after cleaning the laser unit.you need to calibrate the machine if this happens.you can find it on the menu.
            • JustManuals
              • Jan 2006
              • 9919
              Paul@justmanuals.com
              HP has always had problems with magenta, going back to the 4500.
