Hp LJ4250
  • rasman67
    Hp LJ4250
    I have a customer that has a maintenance code. I'm looking for how to reset the code. Is their a fuse or a reset procedure that needs to be done. The fuser looks good and all the rollers are fine so they really don't want to put out the money for a kit if they don't have to.
    Thanks in Advanced
  • prntrfxr
    • 1622
    Re: Hp LJ4250
    Do this at your own risk. Note the DO NOT in the attachment. This procedure is different for the 4200/4300 series.
    • adam_system
      Re: Hp LJ4250
      Service menu (service PIN codes)
      Authorized HP service technicians can use this menu to gain access to printer settings that are
      reserved for service personnel. The service menu is protected by use of a personal identification
      number (PIN). When you select SERVICE from the list of menus, you are prompted to type an eightdigit
      PIN code.
      NOTE The printer automatically exits the service menu after about one minute if no menu
      items are selected or changed.
      Use the PIN codes provided in the table Table 7-5 Service PIN codes
      Printer model PIN code:
      HP LaserJet 4200 Series printer 11420002
      HP LaserJet 4250 Series printer 09425004
      HP LaserJet 4300 Series printer 11430002
      HP LaserJet 4350 Series printer 09435004
      1 Press (SELECT button) or the MENU button to open the menus.
      2 Use (UP ARROW button) or (DOWN ARROW button) to scroll to SERVICE, and then press .
      3 Press or until the first digit of the PIN code appears. Press to save that digit. Repeat this
      selection procedure until you have typed the entire eight-digit PIN code. You can use (BACK
      ARROW button) to return to a PIN digit. When the last digit is saved, the service submenu appears
      on the control-panel display.
      4 Use or to scroll to the service-menu item that you want, and then press .
      ■ Clear event log. Select this item to clear (reset to zero) the internal event log.
      ■ Total page count. Select this item to set the total number of pages that have been printed todate.
      Typically this is only required when a new formatter is installed.
      ■ Maintenance count. Select this item to set the number of pages that have been printed since
      the last maintenance kit was installed or the total number of pages that have been printed on this
      printer if a maintenance kit has not yet been installed (during the first 200,000 pages).
      ■ Maintenance interval. Select this item to specify the number of pages that can be printed before
      a maintenance-kit-required message appears on the control-panel display to indicate that a
      maintenance kit is required.
      ■ Serial number. Select this item to update the serial number if you replace the formatter.
      ■ Service ID. Select this item to specify the date when the printer was first used, rather than the
      date that a replacement formatter is installed. See Restoring the Service ID.
      ■ Cold reset. Select this item to reset the default paper size when you replace the formatter or
      restore factory settings (see Resets submenu). When you replace a formatter or restore factory
      settings in a country/region that uses A4 as the standard paper size, use this item to reset the
      default paper size to A4 (see Cold reset). Letter and A4 are the only cold-reset values available.
