HP M4345 scan to folder
+ More Options
Posts
  • Hopper
    • Jul 2008
    • 173
    Question: normally I will set up a new user account on a PC so that I can set up scan to folder. The needed information is
    WORKGROUP
    path \\hostname\scanfolder
    User
    Password
    My question is this: if I have an end user that does not have a username and password set up to log onto his computer what do you do for username and password. Can it be left blank? This is the way a PC is right out of the box.
    If I set up a username Scans and password scans then they will have to log on to their computer rather than just booting it up.
  • copymech
    • Sep 2011
    • 196
    Re: HP M4345 scan to folder
    enter user name and leave password blank, did this just the other day.
    • copymech
      • Sep 2011
      • 196
      cntrl, alt, del, will show the default user name, mine is owner. for an example.
      • Hopper
        • Jul 2008
        • 173
        Thank you both. The other ongoing challenge is that Windows gives you all CAPS vs at a dos prompt type in hostname and it normally is in lower case.
        I always use how it is printed at DOS prompt hostname.
        • TheOwl
          • Nov 2008
          • 1732
          Start
          Run
          control userpasswords2
          Untick the box up the top which says "Users must enter a user name and password to use this computer" and you will then need to enter in the username and password of the user that needs to auto logon. If the user doesn't have a password, then leave the password field blank.
