HP 1320n no power on
  • groovy
    • 179
    Hi all,
    my HP 1320 has died.
    I was using it for testing a remanufactured cartridge, power went off and the printer no more power on itself.
    I looked at ECU but no evidence of breaking and the fuse is still good.
    Anyone has experied same issue?
    Luigi - Digitalix
  • prntrfxr
    • 1622
    Re: HP 1320n no power on
    Short in cartridge blew ECU board? If so that would explain fuse not being blown. Fuser is only for large voltages not low ones to the cartridge. I wouldn't put that cartridge in any other printer, if I were you.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • groovy
      • 179
      That cartridge works perfectly in another printer.
      • prntrfxr
        • 1622
        Then the ECU probably just got blown. Stuff happens. To you test toners a lot on the machine or was this just one time? If so that is not normal usage. I know because I rebuild a lot of parts and test machines have a lot less life that machines under normal usage. The contacts may have gotten misshapen and touched something they should not have. There could have been a surge on the line or the board could have been faulty and just chose this time to quit.
