Issue on a CP1215
+ More Options
Posts
  • groovy
    • 179
    Issue on a CP1215
    Hi all,
    my customer has an HP CP1215 that has a problem on USB port.
    I hooked up my pc and the printer doesn't show up.
    In my mind the formatter is dead.
    Any ideas?
  • prntrfxr
    • 1622
    Re: Issue on a CP1215
    It's possible, but it could also be your computer's USB port. Try the following:
    1. Try a different port on the same PC
    2. Try a different PC
    3. Try a different USB cable
    4. Try a different Formatter
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • groovy
      • 179
      1. not tried, look down
      2. tested: same issue
      3. tested: same issue
      4. not tried: it's the only printer i have here.
      Opened up the printer and check the formatter: the only big IC (a Marvell one) looks ok, but it comes hot when i put in the usb cable. Maybe the connector is broken? I checked with a tester but i'm not sure of the result...
