5550dtn Won't boot
  • sauce_boss
    • Oct 2011
    • 26
    5550dtn Won't boot
    has the backlight on but nothing on the display, all three lights are lit on the panel. get an engine test page out. Was suggested to try a new formatter, tried that today and get the exact same symptoms. Printer only has 11k clicks on it. Suggestions?
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    Re: 5550dtn Won't boot
    Maybe you have a bad display?
    • sauce_boss
      • Oct 2011
      • 26
      If that were the case I think I would still be able to print to it and the heartbeat sensor on the formatter would be blinking like normal instead of solid. Ordered memory dimm and firmware flash card today.
      • Rob Sandberg
        • Jul 2008
        • 275
        Turn the power off, pull the network card out of the printer than power back up.
        If it goes ready and the network card is a J615 it is time for a baking lesson (no Joke).
        Rob S
        • David-
          • Feb 2016
          • 5
          I'm having a similar problem.
          After seeing the load RFU over parallel port error we replaced the formatter board since it would not allow us to get in to menus by holding down stop.
          Then we loaded the firmware over the parallel port since the usb port would not load it.
          After that, we restarted it when it said ok and the screen blanked out and doesn't come on. My situation doesn't have a back light. I have the machine now in the shop. I have taken off and put on all customer attachments (hard drive, cf card, Ethernet card). I also put back in the old formatter board to see if it would make the screen come on again. It did not.
          Any ideas?
          • Hewlett Slacker
            • Apr 2015
            • 42
            Its the CF card, make sure and get the right one pre loaded with firmware. Again, make sure your getting/ordering the correct card.
            • Elmtech
              • Nov 2013
              • 155
              Usually back light on but no display is a firmware DIMM or memory DIMM error
              • David-
                • Feb 2016
                • 5
                We have got this machine working.
                We replaced the cf card.
                Now the machine claims that the old imaging units are not genuine. The machine works correctly now and we have delivered to customer. Was this something we could have changed or was it not?
