hp 800ps network card
  • walidcharifi
    • Feb 2011
    • 379
    I haveahp 800ps plotter
    how to configurethe network card
    IP address 0.0.0.0 displaye
  • yourownfree
    • Dec 2007
    • 474
    Re: hp 800ps network card
    connect your computer or laptop up to it with a ethernet crossover cable. Then printout the config page again. you should now see numbers there. If not go into the system menu and turn TCP/IP Ip on and also where it asks you do you want to configure say yes. see if you see any numbers now. If so then you can change those numbers by the system menu or easier yet with your laptop or computer. set your computer to match the IP but change the last three digits to be something different. cant use 255. Then make sure the subnet is the same as is on the printer. Then using Internet explorer type the ip address of the printer in the address bar of the browser. Now you should see the printer on the screen. Go to network tab and change the settings to whatever you want. Once you do your laptop will not see it anymore if you have changed it out of range. You would then have to change your laptop settings to see it again. Piece of cake!
