I currently have my HP CM3530 on a circuit with other things I need to be sure to turn off before using it or it will overload the circuit.
I know my Canon it replaced if left on would wake up from sleep mode about one or more times a day to do some maintenance so I had to be sure to turn it off when not in use so it wouldn't turn on by itself and overload the circuit (does the user turn on during these automatic maintenance cycles? if not then I don't need to worry about it overloading).
Does the HP CM3530 also wake up by itself for maintenance? If so if there an option so it doesn't do this or do I need to keep turning it on like I did with my Canon?
Hopefully soon I'll be able to have it on it's own circuit to avoid this issue.
