Does the HP CM2320 and CM3530 use the same toner?
  • aab1
    End User
    • Oct 2010
    • 305
    I still have toner refills for the HP CM2320 cartridges my previous Canon printer used (the HP branded ones were a lot cheaper than the Canon branded cartridges). Does anyone know if my new HP CM3530 printer cartridges use the same toner? If so I'll use it to refill the CM3530's cartridges, otherwise I'll sell what I have left of it on eBay.
  • Jules Winfield
    • Jul 2009
    • 821
    Re: Does the HP CM2320 and CM3530 use the same toner?
    I don't know about that but if you mix equal parts cyan toner, magenta toner, and sugar in a pitcher full of water it tastes just like grape Kool-aid.
    But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
    • JustManuals
      • Jan 2006
      • 9838
      This information is easily found online, stop asking these dumb questions and asking someone else to do your leg work for you.
      • aab1
        End User
        • Oct 2010
        • 305
        I'm not asking about the cartridges which obviously are not the same, I'm asking about the actual toner powder to refill cartridges. I don't think this information is easy to find if even available.
        I was just about to buy the manual from you but with that kind of reply I'll buy it elsewhere.
        • mojorolla
          The Wolf
          • 2606
          • JustManuals
            • Jan 2006
            • 9838
            Yes it is
            Go ahead, buy it elsewhere, pay more, get less.
            • aab1
              End User
              • Oct 2010
              • 305
              Does anyone know if I can use toner powder refills for the CM2320 in cartridges for the CM3530?
              I want to know if it's compatible or if the powder properties are different and incompatible.
              If I can't find the answer I'll just resell it on eBay for someone with a CM2320.
              • Rob Sandberg
                • Jul 2008
                • 275
                I would suggest you find a toner refiller forum.
                This site has field techs that have seen the damage caused by drill and fill cartridges.
                You now have an expensive printer DO NOT risk damage by using drill and fill.
                Do the world a favor and dispose of the old toner, do not use or resell.
                Rob S
                • Wild Bill
                  • Jul 2005
                  • 774
                  Please stop asking senseless and useless questions and wasting space on this bulletin board.
                  Izzy
                  • bauer
                    • 72
                    He sounds like a brain dead service manager.????????
                    • aab1
                      End User
                      • Oct 2010
                      • 305
                      Can someone please tell me if I can use the toner powder (refill kit) made for a CM2520 in my CM3530? I'm sick of having 6 toner refill bottles here and not even knowing if I can use them in my new printer or not. If they aren't compatible I'll just resell them on eBay.
                      And yes I did search online and could not find if it's the same toner powder for both.
                      I know the reset chips probably won't be compatible but the CM3530 does have a setting to allow refilled cartridges without a new chip.
                      Thank you
