HP LJ 4250 Blank display
  • alexkim
    • Jun 2011
    • 9
    after up grade firmware display (control pannel )keep say cycling power . when It power off & on , display is blank. engin is ok.
    but I tried up grade firmware again
    can't upgrade fimeware . do i have to replace Flash memory card (firmware)? or Is there any way?
    please help any expert man.....
  • prntrfxr
    • 1622
    Re: HP LJ 4250 Blank display
    What firmware did you install? I think you may have installed the wrong one.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • alexkim
      • Jun 2011
      • 9
      Thank you for reply mr. prntrfxr
      here is firmware version If it correct this how can i do ?
      Type: Firmware
      Version: 08_220_3 (13 Jan 2012)
      Operating System(s): Microsoft Windows 2000, Microsoft Windows 7 (32-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Server 2003, Microsoft Windows Server 2003 64-Bit Edition, Microsoft Windows Server 2008 W32, Microsoft Windows Server 2008 x64, Microsoft Windows Vista, Microsoft Windows Vista (64-bit), Microsoft Windows XP, Microsoft Windows XP x64, OS Independent
      File name: lj4240_4250_4350_fw_util_08_220_3.exe (16 MB)
      • prntrfxr
        • 1622
        Above is a link to the instructions, but I don't think you can install it with a blank display. I think the only thing you can do is replace the entire formatter. Use an OEM board if you are not sure of the vendor. If you accidently install a formatter from a 4240 it will downgrade the machine to 4240 speeds. Installing a 4350 board will bring the machine to 4240 level as well. OEM boards have been wiped clean so you can install it in any of those three without problems.
