hp 3015 jams when ppr tray is full
  • jayshere
    • Jul 2025
    [Jamming] hp 3015 jams when ppr tray is full
    this 3015 jams when the ppr tray is full. if its about 1/4 of the way full i can run test sheet all day long. thouseands of prints. there are 4 here so ive swapped tires and trays. i can watch from the rear and the tire spins. also i put tape on the ppr and the tire picked the tape up but not the ppr. so why wont it feed it? i need some help. it will feed when the ppr is lower in the tray.
  • JustManuals
    • Jan 2006
    • 9838
    Re: hp 3015 jams when ppr tray is full
    http://www.justmanuals.com
    Paul@justmanuals.com
    • Wild Bill
      • Jul 2005
      • 774
      It is possible the shaft retainer is brocken and shaft is pushed back, when you load it up it causes this problem.
      This is a bulletin from hp I have.
      Izzy
