when feeding through the ADF
it feeds the first two documents but then freezes up... the first two pages are fed through the ADF but nothing actually scans to the computer.
it just reads "scanning one side" on the Scanner UI until the program times out with an "extended error code 2059"
it still scans from the glass just fine but it appears that the ADF is no longer communicating with the rest of the machine, or the computer. would this be a PCB error? Is this something that can be fixed? or is it just and "end of life" issue.
also this machine has about 85000 scans on it
