paper jam 13.05.00 hplj 9050dn
  • AWR
    • Jul 2025
    I have a lj9050dn less than 8 months od that has stumped me. it is jamming in the fuser ( 13.05.00 jam ). I have replaced PIU, registration assy, fuser delivery assy, fuser, cartridge, transfer roller, and DC controller, but have not solved the problem. Has anyone ad this issue?
  • Wild Bill
    • Jul 2005
    • 774
    Re: paper jam 13.05.00 hplj 9050dn
    Is it very intermittent, Often or everytime jamming with 13.05?
    A page is jammed in the paper
    path at the fuser area.
    The leading edge of the media
    did not reach the fuser delivery
    sensor (PS502) within the
    specified time.
    1 Clear the jam in the indicated
    area.
    2 Close the door so that the
    printer attempts to clear the
    paper path.
    3 If the error persists, replace
    the print cartridge.
    4 Replace the transfer roller
    assembly.
    5 Replace the fuser.
    Izzy
    • Wild Bill
      • Jul 2005
      • 774
      Did you just change the transfer roller or the whole tranfer assembly? Refurbished fuser and Toner cartridges?
      Izzy
      • ucinn
        • Jun 2009
        • 383
        specified time.
        area.
        paper path.
        assembly.
        Is the image on the paper correctly? I had one doing that and ended up being the registration assembly...every so often the jammed piece had the image on it late so there was about an inch leading edge void.
        • Marku
          • Aug 2011
          • 28
          Try enabling toner save mode and decreasing toner density.
