TRI COLOR NOT DETECTED
+ More Options
Posts
  • anand8620
    • Jul 2012
    • 34
    [Error Code] TRI COLOR NOT DETECTED
    I am using HP OFFICEJET4500, recently I got tri color catridge problem even I have changed the color catridge it is showing the same error. I have done cleaning of gold strip with water and bottom plate with head cleaner.
  • good
    • Sep 2012
    • 51
    Re: TRI COLOR NOT DETECTED
    Are you using a generic or oem cartridge?
    Usually you will encounter a problem if you used generic cartridge?
