Printer properly aligned but everything printed from PC is 2mm to the left
  • aab1
    End User
    • Oct 2010
    • 305
    I'm not sure but it seems like since I connected my HP CLJ CM3530 by network rather than USB, everything printed from the PC prints 2mm to the left.
    It is not the printer's calibration because the set registration sheets show it's calibrated properly, it's only prints from the PC that are 2mm to the left.
    What would cause this and how do I fix it? It's a major problem as I often print label sheets and now I can't until this is fixed.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Printer properly aligned but everything printed from PC is 2mm to the left
    Maybe you're not aligned right.......
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Ain't Karma a bitch?
      • Brian8506
        • 1664
        Refresh my memory. If you're 2mm left does that make you a liberal or conservative?
        • Rob Sandberg
          • Jul 2008
          • 275
          I agree, your margins set in the printer probably do not match the margins in the program.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            I somehow don't think that's what Paul was implying.
            • collme
              Ricoh tech
              • 221
              Have you tried moving your pc monitor to the right 2mm, once the printer shifts your print 2mm left it will be in the correct position
