Groaning or rubbing noise froma cp3525 transfer belt
  • accent
    [Misc] Groaning or rubbing noise froma cp3525 transfer belt
    I have a cp3525 that nakes a rubbing or groanong noise that comes and goes. It seems more prevalent when the machine is calibrating. I have replaced the transfer belt assy and gutted the machine to check all the mechanical drive parts with no success. Any help or ideas apperciated.
  • prntrfxr
    • 1622
    Re: Groaning or rubbing noise froma cp3525 transfer belt
    probably bushing out of position
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • Wild Bill
        • Jul 2005
        • 774
        Did you remove toner cartridges 1 at a time? Thats what I would start with and rule out first.
        DISABLE CARTRIDGE CHECK This item allows you to remove a print cartridge to help determine which
        cartridge is the source of a problem.
        Izzy
        • mo0651
          • 1054
          Did you ever isolate your problem? I have one doing the same, and a squeak. Swapped trans-belt. Cartridges are not in contact and squeak continues.
          • nmfaxman
            • 1702
            I would remove the main motor and turn each unit gear by hand till I heard the noise.
