hp cm4540 fuser kit reset
  • micko_gm
    • May 2008
    • 18
    good day,
    is there any reset procedure for hp cm4540 fuser kit ( i have a copy of service manual but there's no reset procedure )...thank you..
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    Re: hp cm4540 fuser kit reset
    The reset is in the new fuser. When you instal it, it will reset.
    • mramlawi
      • Jul 2011
      • 838
      exactly as our friend said ,u must change a new fuser and it will reset i stacked on same pro .
      Distinguished road makes you jewel in rough
      • johnyb
        • Feb 2011
        • 167
        There will probably be a 33 ohm fusible resistor on the fuser somewhere, replace with the same size of resistor and refit!
        • Lasersupplies
          • Jul 2011
          • 221
          Did anyone ever find where the reset fuse is located on the CM4540? I have a perfect working fuser at a customers site and it is flashing the "replace fuser" error message. This has automatically triggered them to believe that the copier is faulty. I don't want to have to replace the fuser when it is working fine and can be reset. Does anyone know the procedure for this please?
          Thanks in advance
          • bigwul
            • Jun 2014
            • 60
            http://www.copytechnet.com/forums/hp...kit-reset.html
            • Lasersupplies
              • Jul 2011
              • 221
              Thanks for your help but this is for the transfer belt and not the fuser. Have you any idea where the fuser needs to be reset?
              • bigwul
                • Jun 2014
                • 60
                Ooops - sorry I can't read!!!
