CM6030 MFP Pannel LCD
  • ccspolska
    • Jul 2008
    • 25
    Hello,
    I've got a problem with LCD panel. After the storm panel was uncalibrated, touching one place caused switching different "button" on panel. I've changed for new one and after 7 days occured the same trouble. Than I noticed the fan on the left side of the panel didn't worked. If it's possible the panel is overheated because of not working fan??
    Regards
    Kondi
  • AngusYoung
    • Aug 2012
    • 22
    Re: CM6030 MFP Pannel LCD
    Originally posted by ccspolska
    Hello,
    Regards
    Kondi
    need to change the memory вшьь on the board formatter.
    To check you can remove it from the scanner. there is the same
