50.49 on HP LJ4350
  • groovy
    • 179
    [Error Code] 50.49 on HP LJ4350
    Hi all,
    looked on service manual but cannot find this error code.
    Swapped fuser but error still here.
    Any ideas?
    Thanks.
    Luigi - Digitalix
  • Rick Martinez
    • Sep 2009
    • 77
    Re: 50.49 on HP LJ4350
    Did you install a new fuser or a fuser from another machine?
    • prntrfxr
      • 1637
      I agree with Rick. A fuser may look like a 4350 but that doesnt mean its a 4350. Verify it. This error sometimes occurs when using a different voltage fuser as well.
      Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
      • groovy
        • 179
        I swapped two fuser on two machines, the first is a 4250 and the second is a 4350.
        The error code stays on the same laserjet, it doesn't swap with the fuser unit.
        In another laserjet 4350 i found the swing gears worn. It is a pain to access there...
        • Rick Martinez
          • Sep 2009
          • 77
          Some times i have to let it reset by itself, leaving it off and unpluged for at least 30 min. before replacing the fuser unit.
          Might want to check the DC controller board.
          • MR Bill
            • 532
            Well I got the book out also. If it's not the fuser then they say DC Controller or power supply. Kind of a guess at this point.
            And yes there is no 50.49 code. 50 . X Up to 7 items . But not 49. anyway you might want to call Parts Now or Liberty tech support???
