Hewlet packard CM 6040
  • CrapAimer
    • 296
    Hi All
    Ricoh trained engineer here. customer has asked me to look at a CM6040 machine
    when switched on machine turns over as if starting up then does nothing, display panel dead etc. customer spoke with there help desk he has taken the controller board out and cleaned the dims etc.
    Any ideas
    Many thanks
    George
  • hp mfp tech
    Re: Hewlet packard CM 6040
    its memory problem which is located on a formatter board on the back side of the machine..you just need to replace the memory thats all.
    • CrapAimer
      • 296
      Hi
      THanks for getting back to me, is this just standard memory chips you can get from any electronic store
      • hp mfp tech
        no. dimm,after you remove your formatter board..its right under your hard drive for you to be able to get to it you'l need to remove the hard drive 1st then get to the dimm...order it from any hp parts provider
        • CrapAimer
          • 296
          Many Thanks
          will give it a try
          • hp mfp tech
            no prob let me know how it turn out.
            • ucinn
              • Jun 2009
              • 383
              Originally posted by CrapAimer
              Hi All
              Any ideas
              Many thanks
              George
              Have had this twice and both times it was the DC controller board.
              • JustManuals
                • Jan 2006
                • 9838
                This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
                Paul@justmanuals.com
                • CrapAimer
                  • 296
                  Hi all
                  we update on the problem, changed the dimm working a treat now, Thanks for all your help
                  • Rich
                    • Mar 2011
                    • 30
                    The memory DIMM on the formatter causes that. Change it and away you go.
                    • Munter
                      Member
                      • Jul 2011
                      • 18
                      Just had this exact same issue. Ordered the Formatter, Op Panel, and Dimm ... replaced all in one go ... no change.
                      Out of mild desperation to get customer back online after waiting for parts, I read this thread and fitted all the old units back into m/c but installed the new Dimm ... m/c boots up as normal and everything works.
