HP CLJ CM3530 Line from top to bottom of every page on toner covered areas
  • aab1
    End User
    • Oct 2010
    • 305
    I noticed not long ago that every page I print has a line from top to bottom that is only visible in toner covered areas AND if the page is held at JUST the right angle with the lighting source. There's also another wider line that's also hard to see.
    Needless to say it's not a major problem but I'm worried this might be a defect with a part in the printer and not a cartridge problem, how can I tell what part is causing these lines?
    I hope it's not an issue with the expensive transfer belt but I have a feeling it might, what else would cause a continuous line from top to bottom of every page on toner covered areas?
  • wseyller
    • Sep 2012
    • 1129
    Is it a white line or lack of toner printed. Could be a one of the laser units block by dirt or toner.
    Sent from my Galaxy Nexus using Tapatalk 2
    • aab1
      End User
      • Oct 2010
      • 305
      Re: HP CLJ CM3530 Line from top to bottom of every page on toner covered areas
      It doesn't seem like a lack of toner, as I said it's only visible from a very specific angle on toner covered areas. It's almost as if something is scratching the print. or perhaps a micro-scratch on the transfer belt?
      • wseyller
        • Sep 2012
        • 1129
        Have you looked at the fused heat roller.
        • Iowatech
          Not a service manager
          • 3933
          Huh, aab1 is back after wanting to delete their account on Copytechnet... be careful, fellow travelers, aab1 might not be at all what they seem to be...
          • Wild Bill
            • Jul 2005
            • 774
            Asking us to pull a rabbit out of the hat again I see...
            The way you ask about the problem automatically would take like 5 more questions from a tech.
            Providing info in a question is important.
            Question; I got a line, what is it?
            How the hell should I know?????????
            Prepare your questions and in the process you might be able to fix it yourself, instead of wanting the the techs here to do all your research.
            Izzy
            • aab1
              End User
              • Oct 2010
              • 305
              The problem has gotten worst in the last few days, there is now a top to bottom line of misfused toner when using thicker paper (I do accordingly adjust the paper thickness settings). I can basically scratch off the toner like scratch off lottery tickets along that top to bottom line of the pages.
              Is my fuser failing already? It has 75% of its estimated life remaining. What would cause one long streak of misfused toner and can it be fixed without replacing the fuser? Can I clean it somehow?
              Please keep in mind I'm an end user using this machine in my home office and I'm not a copier tech.
