HP Deskjet 2050A doesn't print consistanly
  • Shayx
    • Nov 2011
    • 32
    the problem is very illusive and i can not seem to find the specific problem.
    we had a laptop with windows xp that worked with this printer just fine.
    we replaced that laptop with a new dell laptop and windows 7 32bit.
    i've installed the drivers from HP site for this printer, it installed fine, but i have some weird problems.
    when i try to print an Excel sheet that i copied from a different location it just send it to the printer queue then disappear but
    nothing comes out of the printer.
    if i open a new Excel file fill some cells with letters and print, its ok.
    if i print the printers test page, its ok.
    now, i tried switching to a different user and it printed the same files that wouldn't print earlier.
    the user that worked was administrator. so i set the previous user that had the problems as administrator, but that didn't do the trick.
    i'm really confused and i can't seem to put my finger on the problem.
    so just to sum things up, what can cause a printer to print selective files
    and when i try to print it goes to the printer queue, says its printing, the page disappears, but actually nothing happens.
    thanks for any advice.
  • Shayx
    • Nov 2011
    • 32
    Re: HP Deskjet 2050A doesn't print consistanly
    anyone?
    this drives me crazy
    there are files it won't print
    then if i copy the data from the excel file to a new file then it prints.
    i just can not figure out where the problem is coming from.
    i think i'll just throw this garbage printer to the trash.
    • Iowatech
      Not a service manager
      • 3930
      What happens if you use the "Print Preview" function in Excel before you print?
      • JustManuals
        • Jan 2006
        • 9838
        Originally posted by Shayx
        anyone?
        Your best bet before you junk it which is a good idea on it's own merit, is to take it down the hall to FYOP. They specialize in garbage like this printer over there.
        • notiones
          Just delete the printer in this users profile, reboot, and reinstall.
          unplug the printer.
          delete the printer.
          reboot the computer.
          plug in the printer and reinstall the driver.
