Reset Replace Maint. Kit message on Hp P4014
  • Senior
    • Aug 2025
    Hi guys,
    I replaced the maintenance kit on an HP 4014 and for the life of me cannot figure out how to reset the message "Replace Maint. Kit" Any suggestions are greatly appreciated.
    Chuck
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    Re: Reset Replace Maint. Kit message on Hp P4014
    Resetting
    After installing a maintenance kit, you should reset the printer's "Maintenance Count".
    There are two ways to do this, depending on your firmware revision.
    Method 1
    1. Turn the product off.
    2. Turn the product on.
    3. Press and hold down the OK button while the memory is counting. The memory starts counting at 000MB immediately after you turn the power on.
    4. Continue to hold down the OK button until all three LEDs are illuminated.
    5. Release the OK button.
    6. Press the up arrow (Navigation) button until the message New Maintenance Kit appears on the control panel display. If New Maintenance Kit is not an option then you have an old firmware version (see below).
    7. Press the OK button once. Your maintenance count is reset.
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
    • Senior
      I did as instructed three times and it didn't reset the message. Any other suggestions would be greatly appreciated.
      • copiman
        • Sep 2011
        • 861
        Try this. Select menu> service menu> put in 05401508 > go to maintenance count and set to 0.
        • Senior
          Reset!
          Google is wonderous! I followed Method 2 and I was able to reset the message. Thanks for your help.
          Chuck
