My HP CLJ CM3530 has had a problem that's been getting worst and is now unacceptable when using thicker paper. For an entire top to bottom line at the same place on every sheet, the toner is either misfused and scratches off, or literally gets peeled off the sheet by the fuser rollers and re-applied further down on the page in white areas. This only happens on thick glossy or card stock paper, I also set the paper settings correctly.
This is strange since it says the fuser has 75% of it's estimated life remaining. What could have caused this and can it be fixed without replacing the entire fuser?
Some things I suspect might have caused it:
-For a while I printed a few hundred envelopes through tray 1, but they say it supports this
-I do every few weeks print small batches (20 sheets or so) of high coverage prints on 199g/m2 card stock, the printer specs say it supports card stock, but not what weight, for "heavy paper" (not card stock) they say up to 175g/m2 I believe
The fact it's one narrow line that misfuses, I'm more inclined to think it might be the edges of envelopes that might have rubbed off the teflon on that part of the roller.
So is there a fix other than replacing the entire fuser? Can the teflon coated roller be replaced? And more importantly, how do I prevent this? Should I not print envelopes despite HP saying it's ok?
