hp laser printer
  • nih
    • Aug 2012
    • 46
    [Misc] hp laser printer
    Hi good day
    I have this machine by mark hp laser jet 4100 TN.when ready i try to print it give this massage. output bin full clear paper from standard out bin.i need help on that.THANKS IN ADVANCE.
  • mo0651
    • 1054
    Re: hp laser printer
    sensor flag stuck in up position. sensor bad. actuator broke. Call a tech.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • prntrfxr
        • 1622
        It is the flag (actuator) where the paper exits. It is either out of position, broken, or there is too much paper where the paper comes out. It is part of the delivery assembly. If you are a technician or feel confident about your mechanical ability, buy a manual from manuals4you. Replacement instructions are in there.
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
        • CRam007
          It is the sensor is out of position or may be broken unless there is no media in there(Where the paper comes out), or maybe you can see too much paper in this path when you are trying to send a job.
          Good Luck
