CM6030 - 59.C0 error?
  • OutlawTorn
    • Aug 2008
    • 189
    Having this issue and have never seen it before so was wondering what the fix is?
    Thanks.
  • prntrfxr
    • 1622
    Re: CM6030 - 59.C0 error?
    I wouldnt operate on that patient without a manual, BTW. But this should help:
    The developer disengagement motor encountered a rotational error. Reboot the printer. Perform the alienation motor component test in the TROUBLESHOOTING menu. Reseat the connectors of the yellow/magenta developing disengagement motor (J1719). cyan/black developing disengagement motor (J1718), print cartridge PCA (J404, J405, J406, J408), and the DC controller PCA (J141, J142). Check the print cartridge drive unit if the adjustment pin sticks in. Check the main drive unit if the lever locks. Replace the primary transfer roller disengagement motor.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • OutlawTorn
      • Aug 2008
      • 189
      I have worked on these machines fairly extensively but have never seen this error so was just wondering if anyone had any tips really!
      Looks like I will just have to order the motor and probably the formatter.
      • Wild Bill
        • Jul 2005
        • 774
        May be a toner cartridge. Use cartridge disable to find out which on is locked up.
        Izzy
        • JustManuals
          • Jan 2006
          • 9838
          This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
          Paul@justmanuals.com
          • OutlawTorn
            • Aug 2008
            • 189
            Is this one of the component tests? Interested to try this out but can't remember seeing it in the manual.
            • Wild Bill
              • Jul 2005
              • 774
              Disable cartridge check
              Use this diagnostic test to print internal pages or send an external job to the product when one or more
              print cartridges or image drum pairs are removed or exchanged. The print cartridges and image drums
              are keyed. They must be removed in pairs (for example a black print cartridge and black image drum)
              and can only be used in the correct color slot. While the product is in this diagnostics mode, consumable
              supply errors are ignored, and you can navigate the menus. This test can be used to isolate problems,
              such as noise, and to isolate print-quality problems that are related to individual print cartridges or image
              drum pairs.
              NOTE: Do not remove or exchange print cartridges and image drums until after you start the disable
              cartridge check diagnostic.
              NOTE: Anytime a print cartridge or image drum pair is installed or removed while the covers are
              removed, the front door interlock must be manually cycled to simulate opening and closing the front
              door in order for the engine to recognize the change. When the covers are installed, the front-door switch
              is automatically operated.
              1. Touch Administration.
              2. Scroll to and touch Troubleshooting.
              3. Touch Disable Cartridge Check.
              Izzy
